Group: DynoMotion Message: 4175 From: fireup_kev Date: 3/6/2012
Subject: G41 Tool Comp Don't work
How do I use G41 or G42 Tool Radius Comp? It does not seem to be working for me.
Kevin
Group: DynoMotion Message: 4176 From: Tom Kerekes Date: 3/6/2012
Subject: Re: G41 Tool Comp Don't work
Hi Kevin,
Did you see the ToolOffsetsDemo.ngc ?
Group: DynoMotion Message: 4177 From: fireup_kev Date: 3/6/2012
After some trying I was able to get G42 to work for outside offset, but when I switch to G41 going the same direction to get an inside cut, it get Concave Corner error
Kevin
> Hi Kevin,
> Sent: Tuesday, March 6, 2012 12:07 PM
> Subject: [DynoMotion] G41 Tool Comp Don't work
> Thanks,
> Kevin
Group: DynoMotion Message: 4178 From: Tom Kerekes Date: 3/6/2012
Hi Kevin,
It is not physically possible to form an inside square corner with a round tool,  you must radius the inside corners with a radius at least as big as your tool radius.
Group: DynoMotion Message: 4179 From: Brad Murry Date: 3/6/2012
Hello,
When tool comp fails on inside corners, should it not revert to simple offset segments with hard corners?
Or does this geometry have an inflection that prevents a continuous offset contour from being generated?
-Brad
Sent: Tuesday, March 06, 2012 9:22 AM
Subject: Re: [DynoMotion] Re: G41 Tool Comp Don't work
Hi Kevin,
Sent: Tuesday, March 6, 2012 1:13 PM
Subject: [DynoMotion] Re: G41 Tool Comp Don't work
Kevin
> Hi Kevin,
> Thanks,
> Kevin
Group: DynoMotion Message: 4182 From: Tom Kerekes Date: 3/6/2012
Hi Brad,
Not sure exactly what you mean, but I suppose an option could be added to ignore GCode errors and perform some fallback result.
Group: DynoMotion Message: 4189 From: fireup_kev Date: 3/6/2012
I try to insert the G-code from this web site that show's G41 code and it does not seem to work in DynomotionCNC
http://www.cncezpro.com/g41m.cfm
It draws the first "D" shape profile but does not do the inner shape...?
> Hi Kevin,
> Kevin
> > Hi Kevin,
> > From: fireup_kev <kliboon@>
> > Thanks,
> > Kevin
Group: DynoMotion Message: 4194 From: Tom Kerekes Date: 3/7/2012
Hi Kevin,
As I said it is not possible to make angled internal corners with a round tool.  Although I did try it in Mach3 and it does allow the path. I suppose we could add similar behaviour.
Sent: Tuesday, March 6, 2012 6:34 PM
> Hi Kevin,
> Kevin
> > Hi Kevin,
> > Thanks,
> > Kevin
Group: DynoMotion Message: 4196 From: fireup_kev Date: 3/7/2012
It would be great if you can make it work like others (Mach3,Fanuc,Haas). Some of my customer rely on G41/G42 as they already have the g-code and need to adjust the tool size to make the part fit. Going back and regenerating the g-code from the start is not desirable or feasible for them. So for now, I will have them switch back and use Mach3.
Kevin
> Hi Kevin,
> > Hi Kevin,
> > Kevin
> > > Hi Kevin,
> > > Regards
> > > Thanks,
> > > Kevin
